Salta al contenuto principale
Samsung ha annunciato la linea Galaxy S24 durante l'evento "Unpacked" del 17 gennaio 2024. Il Samsung Galaxy S24 è il modello base del flagship del 2024.
Screen + frame replacement Samsung S24
Hello!
I replaced the [screen+frame] unit on my S24, and the buttons ont the side of the phone don't work anymore. The screen works when I put the phone on charge but I only have a logo with the circle and the little lightning for a few seconds.
Can anyone help me to fix this please?
Thanks a lot :)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Is the phone charging? I know you see the lighting logo but, does the green circle increase? If so, we know the phone is atleast taking a charge.
The S24 replacement part with frame usually has the power button and volume button built into, so you dont have to transfer them. I would check to make sure though. Usually, you can tell if the buttons click properly or not.
Punteggio 1
2 Commenti:
Thanks for your answer! No, the green circle doesn't increase. I had to transfer the buttons but I did it well and easily. The buttons click properly.
da
You're welcome. I would double check all the connections such as the battery and charge port. The fact that the battery isnt charging leads me to believe the charge port isnt being seen by the mainboard. Once the phone is taking a proper charge and you see progress on the screen that the phone is charging, I would test the power button again.
da
Aggiungi la tua risposta
Haha Hihi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 33
Tutti i Tempi: 542
