Salta al contenuto principale
Il Samsung Galaxy S8 Active può essere identificato dai numeri di modello SM-G892A (AT&T) e SM-G892U (T-Mobile e Sprint) ed è stato rilasciato nell'agosto 2017. Il Samsung Galaxy S8 Active è uno smartphone Android prodotto da Samsung Electronics come ottava generazione della serie Samsung Galaxy S.
Samsung S8 active overheating
Everything turned on normally, heating at around 50°C on the motherboard whilst charging
here are the temperatures, hope y'all can help me
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
You need to open up the phone and see the component that causing the heat using a thermal camera. Sorry but I guess you need to take it to a technician.
Punteggio 0
Heating more than normal while charging is a sign your battery needs replacing.
If the battery over heats, it will obviously heat a lot of other things since it covers a large area.
Do a battery test and see if that gives a clue.
Punteggio 0
@jamesleebron connect an ammeter between your charger and your phone. See how many amps it is pulling. This can be an issues of the charging circuitry (bad PMIC, failed Battery controller etc.) Make sure that you have a good USB cable and that your charging port is in good working condition. Check the pins for corrosion etc. After that you will have to open it up and check for any damaged or disconnected components. A new battery is always advice but do not ignore the charging board Sostituzione scheda figlia I/O Samsung Galaxy S8 Active
Punteggio 0
Aggiungi la tua risposta
James lee bron sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 3
Tutti i Tempi: 170
