Salta al contenuto principale
Modello A1347. Rilasciato il 21 luglio 2011. Processore Core i5 o Core i7. Thunderbolt. Questa unità è utilizzata anche per eseguire la configurazione Mac mini Server.
Mac Mini resets itself
My Mac mini, 2.5GHz Dual Core i5 "Mid 2011" (High Sierra) resets itself several times a day.
 performed an NVRAM, performed an SMC reset, booted on Safe mode, changed memory module, without success
  I would really appreciate some ideas to start looking for the cause.
Update (02/15/25)
Found on this site:
"I disagree with the power supply diagnosis. Unless you have set your power save options to restart after power fail, the machine will stay off. Mine does not stay off. None of the others reporting this issue claim it stays off.
I was having the random restart problem several times per day after updating to High Sierra. The suggestions above caused me to start thinking about what functionality might change across releases. I decided to look at Power Save options.
I disabled power save for both system and display (set it to Never). The problem has disappeared. I have been running for a week now without recurrence.
It appears that Apple has introduced misadventure into the Power Save behaviour of (at least) High Sierra on Mid-2011 Mac Minis."
Questa è una buona domanda?
Punteggio 0
1 Commento
Found on this site:
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
What Apps are you running? Was one updated on you when you started to have issues? Remove any apps from your startup list to see if that helps.
You may want to review the Activity Monitor App under the Utility folder to see what’s running for processes and which are using more and more memory. See if the log file shows a crash event.
Punteggio 1
1 Commento:
Thank you very much Dan for your prompt and kind reply.
I will do as you suggest.
da Condividi
Aggiungi la tua risposta
Pedro Miteff sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 7
Ultimi 30 giorni: 19
Tutti i Tempi: 242
