Salta al contenuto principale
Guide di riparazione, smontaggio e informazioni per la risoluzione di problemi per la terza versione del popolare Mac mini, il piccolo PC fisso della Apple, lanciato sul mercato nell'ottobre 2024. Dotato di SoC M4 e M4 Pro e di almeno 16 GB di memoria unificata.
Upgrading Storage / restore step
I have a question about upgrading the storage on the new Mac Mini M4. I bought the base model. I have the 2T SSD card upgrade on the way from store.m4-ssd.com. I haven’t even turned on the mini yet. I am confident that I can switch out the SSD physically. But I am unclear about how to get the 2T SSD card to work. I don’t have an extra Mac lying around to use Apple Configurator. I do have a Surface Pro running windows. Can I restore the Mac mini from iTunes? The surface has 2 x USB-C® with USB 4.0 / Thunderbolt 4. So I would just have to download iTunes, run iTunes when I and connect the Mac mini to the surface pro, and turn on the mini in DFU mode. Do I have these steps right?
Or is the only way to do this is with another Mac?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta più utile
The required method is using the Apple macOS tool Configurator tool from a second Mac connected via a USB-C Thunderbolt compliant cable. Time to find a friend with a M series Mac who can help you out.
Reference:
Punteggio 2
As an alternative, if you have a Linux box lying around you can build the idevicerestore project. I used the same SSD from m4-ssd.com and used the idevicerestore project to flash the drive. Some distros have the binary present but I found the the version distributed did not detect the newer M4 models. After building from source the M4 was recognized and I was able to flash.
https://github.com/libimobiledevice/idev...
Punteggio 0
1 Commento:
Sorry they won’t work here. Apple uses a serialization strategy which requires access to multiple chips within the system, similar to how the iPhone is protected.
da
Aggiungi la tua risposta
Leanna Keightley sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 23
Ultimi 30 giorni: 64
Tutti i Tempi: 3,234
