Salta al contenuto principale
Rilasciato a luglio 2020, numero di modello ZS661KS-6A006IN
My screen is ghost touch
I hold the screen on one point but it keep moving
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
While Jhon's suggestions are an excellent way to start and well worth trying, in my experience the ghost touch phenomenon is most commonly caused by damage to the digitizer. There are delicate connections between the ribbon cable connected to the digitizer and the circuits printed on the glass, and when those connections get disrupted you end up with electrical noise being introduced on the signal lines. The motherboard receives those bogus signals and tries to interpret them as touch inputs.
Unfortunately, it's not practical to repair those connections, as it requires specialized equipment and expertise. So for us normal human beings the fix is most often to replace the screen, giving you a new digitizer that will resolve the issue.
I was unable to locate any iFixit-style guides to that repair on your phone, but I did come across a YouTube video that shows the procedure in fairly good detail.
STILL VERY EASY TO FIX? ASUS ROG Phone 3 Screen Replacement - Sydney CBD Repair Centre - YouTube
Hopefully that's everything you need to know. Good luck and let us know how it all turns out! Feel free to ask if you have any questions.
Punteggio 1
Well I will suggest you to update your phone to it's latest version it might help you in fixing the issue of ghost touch. For more solution to your problem I will suggest you to check out the following:
https://tweaklibrary.com/how-to-fix-ghos...
Punteggio 0
Aggiungi la tua risposta
Malik Ziyech sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 18
Ultimi 30 giorni: 54
Tutti i Tempi: 725
