Salta al contenuto principale
Presentata al New York International Auto Show nell'aprile 2003 per l'anno modello statunitense 2004, la Prius è stata completamente riprogettata. È diventata una liftback di medie dimensioni, posizionata tra la Corolla e la Camry, con una ridistribuzione dello spazio meccanico e interno che ha aumentato significativamente lo spazio per le gambe nei sedili posteriori e il bagagliaio.
ABS light has problems
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta più utile
Herold, as bill was trying to say in his own inimitable way, you have't given us enough information to figure out what's wrong with your car, let alone come up with a fix.
What do you mean when you say the ABS light has problems? Are you just saying the ABS light is on? Or do you mean the ABS bulb is out? As you can see, with only the four words you said, we can't possibly know what the problem is.
If the light is on, you will need to get the ABS system scanned with a reader that can access it; a standard OBD-II reader won't be able to, so as much as I hate to, I would suggest going to a mechanic for a diagnosis. Wheel speed sensors are a common problem with ABS systems, but certainly not the only one possible, so a scan is essential for the proper diagnosis.
Update (01/23/25)
I might add that this is something that is important for you to do, being a safety feature of the car. Your Anti-Lock Braking system will not function as long as the light is on, and if your car is equipped with traction control, that will be disabled as well.
Punteggio 1
Aggiungi la tua risposta
Herold Pierre sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 169
