Salta al contenuto principale
Stampante multifunzione a colori digitale compatta con touchscreen a colori da 3,7", stampa e scansione fronte-retro e wireless.
Paper jam error will not clear
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
i believe i got very deep into the rollers... I had two sheets of paper wrapped around one of the padded rollers.. I had to tear them out to get them off the rollers.. I looked and looked for other paper and could not find anything.. any good videos on this.. or can you take photos on what you did... I went in the front and back... I took screws off in back.. removed all the toner and looked down..
Still have same paper jam error
Punteggio 0
1 Commento:
Quite possible the sensor arm got distorted while tearing the jammed paper out.
da Condividi
That could be a hardware problem with stuck sensors BUT every time it happened to me, there was paper buried so that it was very difficult to find. You may have to open/remove more parts to get to it.
Punteggio 0
1 Commento:
Agree, and just to add: the few times I've dealt with this: 1 - small piece of torn paper stuck deep inside. 2-small piece of metal found in the paper tray (no joke!), and 3 - had to just flip/toggle every sensor to be found.
da Condividi
Aggiungi la tua risposta
Neil Feldhacker sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 19
Ultimi 30 giorni: 80
Tutti i Tempi: 1,029
