Salta al contenuto principale
Il terzo aggiornamento del controller wireless dell'Xbox è stato rilasciato a novembre del 2020, insieme all'Xbox Serie X ed S. Il controller è anche compatibile con i precedenti modelli di console Xbox One e i PC.
How can I fix connection between the 2 boards
The connection between the 2 boards in my controller are acting up, when the top board is lightly placed in the connector everything is fine but when pushed in completely light goes out on front batteries don't work and connected with a cable there is a noise like a coil whine come from the controller buttons still work tho! Any ideas on the problem and possible fixes would be appreciated thanks.
Update (01/22/25)
Have checked and cleaned pins couple times and they look OK to me see what you think
Questa è una buona domanda?
Punteggio 0
2 Commenti
@karl56764 let's see if our console Guru @dan0 has an answer for you.
da
Hi Karl! In the 1st photo, the pins do look dirty! Can you try to clean them with isopropryl alcohol? And then share a photo with us again? In the worst case, that one need to be replaced..
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Karl!
Check the pins on the connector. It’s possible that one or more pins are bent and thus not making a good connection! Please check all the pins if they are OK.
Clean the pins as well and see if that makes a difference. In the worst case, you need to replace the connector with the pins (upper board) to get it fixed.
Please show us some photo’s if possible! Thanks!
Punteggio 1
2 Commenti:
Hi i have since cleaned both connectors again and resoldered the connector pads and this has resolved the issue thanks
da
Good to hear!! Glad that it's fine now :)! Have fun gaming and take care!
da
Aggiungi la tua risposta
Karl sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 118
