Salta al contenuto principale
Supporto per la calcolatrice Texas Instruments TI-84 Plus.
Line of keys not working.
I've had my calculator for years and use it frequently. Today, an area of keys - specifically "0", "1", "4", "7", ",", "sin", "apps", "x^2", "(", ")" stopped working. All other keys work fine. I've tried restarting, system reset, and changing batteries. I don't know if it's possible water damage (I have cats) or something else.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If a column of keys stops working that typically means it's a hardware problem. You might have success taking the calculator apart and cleaning the button side of the circuit board with isopropyl alcohol.
However, it's likely you'd also need to do a board level repair using soldering equipment. Water damage and corrosion can certainly cause issues like this.
Punteggio 0
Aggiungi la tua risposta
Milo Moss sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 151
