Salta al contenuto principale
iMac G4 17" 1.25 GHz Model M9168LLA PowerMac 6,1 introduced in 2003.
21 Domande Visualizza tutte
modulo bluetooth e antenna (Transl: Bluetooth module and antenna?)
Salve.
Possiedo un iMac G4 1.25 Ghz (usb 2.0) ed avrei intenzione di installare il modulo bluetooth. Sapete dirmi se è necessaria anche l'antenna ed eventualmente mi indicate una guida per l'installazione?
Grazie.
Translation:
Hi.
I own an iMac G4 1.25 Ghz (USB 2.0), and I'd like to install the Bluetooth module. Could you tell me if I need the antenna too, and, eventually, if and where I can find an installation guide?
Thank you in advance.
Questa è una buona domanda?
Punteggio 0
1 Commento
iMac USB 2.0 - M9168LL/A - PowerMac6,1 - N/A - N/A
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
First and foremost, we need the last three letters and numbers of your serial number, to gauge exactly what's your machine.
Second: as far as I know about your model, and assuming your iMac never had Bluetooth beforehand, you need two parts I don't see listed here in iFixit, plus the screws.
The Bluetooh module itself, P/N 922-6876, five screws (P/N 922-6680) and the Bluetooth Antenna and Carriage (P/N 820-1532-A).
Oddly enough, the only site carrying those parts, lists the BT Module as surely compatible with the G4, and while lists the Antenna Assembly as a G5 part, it also describes the Antenna Assembly, in the BT Module page, as "necessary for the BT Module".
I can understand that: even if the BT module would still be recognized without an antenna, you'd probably get a reception so bad to make the part unusable.
Thus, if I were in your place, I'd get an external USB dongle: nowadays they're all compatible with OS X. If you want to keep the aestethic, go for the replacement.
Sadly, I wan't able to find any take apart guide, save for the service manual in the Darryl's Take Apart Guide, that's always a good starting point. I'd still advise you to stick with a less costly and hard to install external dongle, though.
Italiano:
Per prima cosa, dovresti fornirci le ultime tre lettere e cifre del numero seriale del tuo computer, per valutare esattamente di che modello ed allestimento stiamo parlando.
Per seconda cosa: per quanto ne so sul tuo computer, ed assumendo che il tuo iMac non abbia mai avuto il bluetooth installato, hai bisogno di due parti che non vedo qui in vendita su iFixit. Più le viti, naturalmente.
Il modulo Bluetooh, P/N 922-6876, le viti (P/N 922-6680) ed il kit antenna più supporti (P/N 820-1532-A).
Stranamente, l'unico sito che mi mostra quelle parti mi mostra il Modulo BT come sicuramente compatibile col tuo computer, mentre mi dichiara il Kit Antenna una componente del G5, ma precisa che il kit antenna è indispensabile per il corretto funzionamento del bluetooth.
Posso capire e dirti anche il perché: anche se il BT fosse riconosciuto, senza un'antenna avrebbe una ricezione così pessima da essere di fatto inutilizzabile.
Per tali ragioni, se fossi al tuo costo, prenderei un dongle esterno: al giorno d'oggi sono tutti compatibili con OS X. Se vuoi mantenere l'estetica, vai con la sostituzione con componenti Apple.
Mi spiace, ma non ho trovato delle guide, salvo il manuale di servizio e riparazione sull'ottima Darryl's Take Apart Guide, che è un buon punto di partenza. Fossi nei tuoi panni, comunque, acquisterei un dongle esterno.
Punteggio 5
3 Commenti:
Sei stato chiarissimo e ti ringrazio molto.
Il dongle esterno ce l'ho e lo uso tranquillamente....
Era semplicemente uno sfizio, l'iMac G4 è troppo bello quel dongle mi infastidisce parecchio dal punto di vista estetico... :-)
Di nuovo grazie.
da
I'm sure you could, with a great deal of efforts, fit the internal bluetooth adapter and the antenna assembly, maybe having to use some kapton tape if the antenna assembly feels precariously lodged. But I also believe that such work would be too much an involvement for a spur-of-the-moment upgrade. If the stylistic quality of the USB dongle bothers you, there are some USB dongles that are really small, little more than almost invisible plugs. I bought one for my netbook, obviously in Italy, where you live too. Try by Euronics... I'd rather do that than embarking in such an upgrade path.
Cheers, and good luck with your iMac :)
da
Sono certo tu possa, con molti sforzi, installare l'adattatore bluetooth interno ed il kit antenna, forse usando del nastro kapton se il kit antenna ti sembra precario ed in bilico. Ma ritengo che tale impresa sembra un po' spropozionata per essere un semplice sfizio. Se l'aspetto estetico del dongle USB ti infastidisce tanto, ci sono dei dongles USB davvero piccolini e ben fatti, quasi dei tappini invisibili. Ne ho comprato uno per il mio netbook... e naturalmente sono Italiano anche io. Prova da Euronics: è ciò che farei io piuttosto che tentare un upgrade così complicato. Auguri, e buona fortuna per il tuo iMac!
da
Sapete gentilmente indicarmi come installare il modulo BT nell'iMac?
Ho cercato sulle guide online ma non ho trovato indicazioni per il montaggio.
Grazie a chi vorrà rispondermi.
Punteggio 0
Aggiungi la tua risposta
dueannidopo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,643
