Salta al contenuto principale
Questo Moto G con tecnologia 5G è dotato di un display LCD da 6,5 pollici, 720 x 1200 pixel e 90 Hz, chipset MediaTek MT6833 e fotocamere grandangolare da 50 MP, macro e di profondità.
How to clean proximity sensor?
The display on the top side got unglued a few weeks back and I didn't bother to fix it. Now after ending phone call the proximity sensor turn off my display until I lock and unlock using buttons.
I believe it is due to some dirt accumulated on the sensor. What is the best way to clean it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would run a hardware test on your phone to confirm this. There's a convenient iFixit guide for this. Secondly, you'll need to tear down the device a bit to clean it. I'm unsure if you'll need to remove the LCD panel, but there's a repair guide. You can clean it with some Q-tips and some isopropyl alcohol, but I can't give too much guidance on that.
If cleaning doesn't work, I can only recommend replacing the device's LCD frame or mid-frame housing. The mid-frame housing does contain some small components, potentially the proximity sensor. Also, it's essential to ensure you place proper adhesive post-repair.
Punteggio 0
Aggiungi la tua risposta
Kishore Kumar S sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 20
Tutti i Tempi: 380
