Salta al contenuto principale
Repair and troubleshooting information for the HP EliteBook 840 G6, an HP laptop part of the HP EliteBook series. Released in May 2019.
Screen change for my hp
How do I change my screen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @saitotigideon
Here's the maintenence and service guide for the laptop.
Go to p.70 (80 of 122 pdf) to view the procedure to remove/replace the display assembly.
On p.76 it shows how to remove the LCD panel from the display assembly.
Also on p.76 there are the HP part numbers for all the different LCD panels that can be used in the model.
Search online for the appropriate to your particular model LCD panel part number to find suppliers that suit you best. Usually the HP part number can be found somewhere on the back of the LCD panel itself, if you want to verify that you're ordering the correct one.
Punteggio 1
Aggiungi la tua risposta
Saitoti Gideon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 26
Tutti i Tempi: 240
