Salta al contenuto principale
Guide di riparazione, manuali e aiuto nella risoluzione problemi per il saldatore smart FixHub Power Series. In uscita a ottobre 2024.
Is there documentation for the serial console
Is there any documentation for using the serial console when directly connecting the smart soldering iron to a PC?
The web console is great but not always an option if you are in an offline environment. I see that there is a basic help command but it does not seem to give much detail on individual command usage.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
@jeffp96603 , we're working on the documentation. I don't have an exact date for when it will be publicly available, but we are working on it.
Punteggio 3
1 Commento:
Is it out yet?
da
According to this GitHub repo, there are some very limited serial interface commands that work with FixHub and the Smart Soldering Iron: https://github.com/iFixit/FixHub
According to this FixHub Station review from Hackaday in September 2024, it's possible to access the serial interface via PuTTY: https://hackaday.com/2024/09/12/review-i...
However, if you're on Linux, then you should use minicomp in a terminal emulator session (and get the current serial interface port in use by FixHub/the Smart Soldering Iron via the WebUSB prompt in any Chromium-based browser, such as Google Chrome or Brave Browser).
Punteggio 1
Aggiungi la tua risposta
JeffP sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 14
Tutti i Tempi: 476
