Salta al contenuto principale
Una serie di computer desktop mainstream venduta da Hewlett-Packard tra il 2011 e il 2013.
Pc resolution too high.
The pc resolution is too high for my screen.My pc is black the resolution won't turn down the mouse isn't responding so as the keyboard,the keyboard has LEDs which indicates it has power.i can't go into bios to fix it how can I fix the issue.
Questa è una buona domanda?
Punteggio 0
1 Commento:
How do you know its the screen resolution and not something like the GPU failing, also is the keyboard/mouse plugged into the computer?
da
Aggiungi un commento
2 Risposte
What do you mean the resolution is too high?? I believe you have failing hardware, like the previous comment said you may have a failing gpu or user error.
Punteggio 0
@tshepophansi just like everybody else on here, we can't see where this would be a resolution to high issue. I wonder why you think that it is. Is there a possibility that you have set something on your video card settings (or yuor BIOS settings) that may correspond to the refresh rate etc. If so, it'll be helpful to know what that was.
If this would just be a screen issue I would have said connect another display via VGA or DVI etc. but since you are also experiencing issues with your mouse and keyboard, this is most likely a motherboard issue or a BIOS issue.
Try this. Disconnect your computers power cable. Then remove your RAM modules. Plug it back in and turn it on. Let us know exactly what happens. You also want to use a different keyboard and a different mouse.
There are a few different P6 models. We will need to know your exact model.
Punteggio 0
Aggiungi la tua risposta
Tshepo Phansi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 28
Tutti i Tempi: 252
