Salta al contenuto principale
Informazioni su riparazione e soluzione problemi per l'HP Probook 450 G5, un portatile HP che fa parte della serie HP Probook. Commercializzato a settembre 2017.
How to replace IC of system board
My system board is water damaged and i want to fix the board. When i turn on my system it automatically power offs after 2-3 minutes of start. How to fix that problem
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello! Here is one guide I have found on YouTube if you wish to do it yourself: here, also if you wish to not do it yourself you are going to have to take it to a repair place in your local area such as Best Buy to get them to fix it for you. Note: Make sure you have the right tools for the job such as the ifixit Pro Tech Toolkit or something that will work.
Immagine The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.
Prodotto
Pro Tech Toolkit
$79.95
Punteggio 0
Aggiungi la tua risposta
Turab Ali sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 9
Tutti i Tempi: 223
