Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti:
Have you adapted the current AC system in your truck? If you haven't, you need R-12 Freon, which is extremely difficult, if not impossible to find if you don't have a certification. Also, in order to properly convert to R-134A, you may need a new compressor, which will be able to handle the higher pressure required for R-134A. You will need a new orifice tube, R-134A barrier tubing, low pressure switch, accumulator drier, a retrofit kit, o-ring kit, and R-134A Freon. You need to purge the AC system of all R-12 before adding the new R-134A Freon. As far as the oil goes, you will need to know the model of AC compressor to know how much oil to put into the system. After all of this is completed, You will need to get a vacuum pump and evacuate the system.
da nealhatfield
The system is new and flushed compressor is the same size as the York design.
Just need to the proper pag oil oz and 134 freon charge.
Thanks for your help.
James
da james
