Salta al contenuto principale
Informazioni sulla riparazione, smontaggio e risoluzione dei problemi per lo smartphone di punta "più piccolo" di Apple del 2023, lanciato il 22 settembre. È dotato di un display OLED ProMotion da 6,1", un sistema di fotocamere posteriori a tripla lente e 5G. Successore dell'iPhone 14 Pro.
Face ID doesn't work after front camera module replacement
Hi
Under iphone 15 pro front camera page shows :
"This assembly includes the front-facing camera and Face ID hardware. These parts come as one unit, and the sensors are uniquely paired to your logic board. Replacing the front camera assembly means you'll lose Face ID functionality and, as of iOS 17.0, may still experience issues using your front camera."
I replaced the front camera and the Face ID doesn't work. Is there any solution to active the Face ID function?
Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
try updating to ios 18, it is giving options to replace genuine apple parts
Punteggio 2
1 Commento:
That what I am thinking. I am going to order a genuine apple part.
da
Hi,
Yes there is, but it’s probably going to be a visit to the repair shop if you don’t have the equipment or skills to do it.
https://m.youtube.com/watch?v=cKeEh3huvK...
This is a list of videos that cover FaceID repair, once you have watched some you’ll understand why and how it can be done then choose what steps you want to take.
Hope this helps
Punteggio 1
Aggiungi la tua risposta
Caleb sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 23
Ultimi 30 giorni: 59
Tutti i Tempi: 1,198
