Salta al contenuto principale
Informazioni e guide di riparazione per la versione aggiornata del Retina MacBook del 2015, rilasciata all'inizio del 2016. Modello A1534 / EMC 2991
Force Trackpad Weak After Assembly
Hey all at iFixit.
I am working on this MacBook, and I have been using it for a few months now without any issues. Yet, I couldn't help but notice that the force trackpad was very weak. I could hear the click, but I could barely even feel it. I took the machine apart, but the trackpad felt fine. After a snapped the lower case back on, the trackpad became weak again. Something happens when I snap the lower case on, and the trackpad loses power. I feel like something might be bent on the lower case, but nothing appears off.
Should I look somewhere else? Why would the trackpad lose power by simply putting on the lower case?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
I would take a straight edge to see if the case is not caved in either side. Also check if the case is warped so diagonal corners appear to not lay flat on a known flat surface.
If you don’t detect any issues then I would summarize the TouchPad is damaged and will need replacement.
Punteggio 0
1 Commento:
@danj - Turns out the lower case was bent a little, I took some clamps and bent it back in place, trackpad feels great now!
da
Aggiungi la tua risposta
Jadon Lyon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 19
Tutti i Tempi: 220
