Salta al contenuto principale
Una cappa aspirante è un elettrodomestico da cucina installato sopra i fornelli, progettato per rimuovere fumo, odori, calore e grassi in sospensione tramite filtrazione e ventilazione.
Interlock Switch Bracket Installation
Anybody know how difficult it is to replace an interlock switch bracket (lower switch bracket assembly, part # 97009972) on a Kenmore Downdraft Vent/Blower (model # 233.5994690)? Do you have to remove a few panels to access the interlock switch or is it more involved?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
here is the diagram. You will have to figure out how hard it is to replace.
Immagine
Item 10 is the switch. It is a V7-1B17D8-048 which is available from sources other than the Kenmore.
Punteggio 0
1 Commento:
Thanks. I've got that schematic and am thinking to replace the interlock switch bracket assembly you probably need to nearly take the whole thing apart. Hoping someone can confirm/refine that assessment before I decide what action I'm going to take.
Thanks again
da Condividi
Aggiungi la tua risposta
James Brooks sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 25
Tutti i Tempi: 261
