Salta al contenuto principale
Potente portatile HP per l'intrattenimento
DC input jack broken.
Is there two models of the HP Pavillian zd7000 as some of the instructions and photo's differ to mine? For instance, Ram cover needs removing to allow access for screen wire removal. Also the top fan is connected to the heat sink frame and has to be removed before not left in place until later in the process.
When all instructions and screw removal is complete the keyboard is firmly fixed on the drawer side but no screws are visible!
I am trying to replace the DC input jack as it has an intermittent connection. The AC DC converter shows a steady 18.6v of output.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Mike Hayes, the instructions for your HP are available here. This of course is not to say that there are no revisions made, but the principal should still be the same. BTW the bad DC adapter is a very common failures on the board. Good Luck.
Punteggio 1
Aggiungi la tua risposta
Mike Hayes sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 11
Tutti i Tempi: 1,426
