Salta al contenuto principale
Annunciato il 14 dicembre 2022. Identificabile dal numero di modello Xiaomi 2211133G
Can I replace the screen?
I shattered my Xiaomi 13- the screen is cracked and not working and the back panel glass is also shattered. Miraculously the camera glasses didnt break but the fall was hard so im not sure if the lenses survived. Is there hope to replace both the screen and the glass in the back?
Questa è una buona domanda?
Punteggio 3
1 Commento
I have a green line appearing on my screen.
da
Aggiungi un commento
2 Risposte
Risposta più utile
il just awnser here so others may see what i was searching
i fixed the screen myself and i can say its made relativly easy
you have to heat it up (ive seen 80 decrees on other phones but that with a special heating plate)
i blasted my phone with a heatgun set to 110 decrees celcius and then carfully lifted first the back off
then you have to remove the module at the bottom(its made quite intuitive only a few philips screwes then caruflly remove the antenna cable
once that is off u can remove the module(again important that you removed all screwes located below the battery (you dont have to do anything with the battery just the screwes that you have on the lower part of the phone) also note that there is 2 types of screwes they used two difrent ones (1 hidden below a sticker) for the charging port
now the module should be free to come out(it is clipped in so it needs a little force but not much
now if u look on ur replacment screen you should see a ribbon cable(its like a loong conector thingy)
you should find the sayme one on the right side (it commes up from the other side)
unplug that
now i am not sure if i went off script that ribboncable was fixxed in the thoughhole with a small plastic pice maby you can remove that now
if not thats ok i didnt but my screen was toast anyway so me tugging quite hard dint make it worse
anyway...
i then went on to the other side again 110 decrees and blasting the phone till i can get a tool in there
again idk if i did the screen right removal was kinda messy for me (i got the glass first and after that the screen
ig its possible just to remove the glass but tbh it seems a lot harder)
then you should be able to peel it off and pull the conector thoug to this side
now to get the new one in
make sure all glass and screen remnances are gone if not you will destroy your new screen
if you have a full kit this gona be easy you should have a new gasket to put in
if ur like me and were a cheap bastard and dint get that kit ... i used B-7000 silicone glue i read thats good for fixing screens so yeah source idk dude on the internet sounded confident
i first tried o0ut if my replacment worked bevore getting messy with glue
after it did i but a thin line of glue evrywhere were gasket was(so all around exept for the speaker and microphone(i think like i said this part i am not confident i did right but dint have any problems with my fix yet)
thenput the ribbon cable though the hole and press the screen on
i dint wait for the glue to dry just pressed it in for maby 60 secs glue has a cure time of 48h
then put the ribbon cable on the conector and but my backglass again with sthe same silicone technik on
then i took a thin pice of wood the same hight as the camera bump(i used shifters so suport both parts and some paper opn the screen side(just somthing so when pressing my phone for the next 48 hours it would have ewqual pressure and not scratch to hell
i checked if its working and then i pressed it for 48...well i got impatient so it was just a bit more than 24 but you should do the full time
afgter that done my phone is fixed
exept the fingerprint sensor for some reson dosnt work could be somthing in softwareor maby i broke it idk but its no0t that big of a inconvinience considering i fixed my phone for about 60 bucks and real phone repair costs around 300-600 depending on wehere in my country id do it
hope this helps sombody have a nice day byeeee
Punteggio 1
1 Commento:
i wanted to add my backglass is also broken but there is like plastic under that so i suspect that even shattered back glass is still watertight i just used mine again but ofc u can replace it when you replace the screen (many repair shops just do both anyway)
da
只要主板没有摔坏 其他的都可以进行更换
Chinese (Simplified)->English translation
As long as the motherboard hasn't been damaged by a fall, everything else can be replaced.
Punteggio 0
Aggiungi la tua risposta
Mae sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 18
Ultimi 30 giorni: 106
Tutti i Tempi: 10,330
