Salta al contenuto principale
Il Lenovo Legion Pro 7 16IRX8H è un portatile da gaming da 16 pollici rilasciato nel 2023 con GPU NVIDIA GeForce RTX 4090 e CPU Intel Core i9. È dotato di 1 TB di archiviazione e 32 GB di RAM.
Why Is my screen flickering
I bought this model off a shopping site (Jumia.com) When it came it was fine until a week or 2 after I noticed whenever I pivot the screen, Bend it forwardor backwards it flickers, sometimes glitches and the other times goes completely black I'd have to press the touch pad sides, tap the screen or alternate the refresh rate to get it working again.
In other cases I'll have to use win cntrl B, I called lenovo support to see if they could hlep and they said there's no warranty for a new device I just got that I should contact my provider, or go to a lenovo outlet near me and Unfortunately for me I stay in Nigeria, there's inaccesaibilty to such stores logistcally.
I haven't seen any
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@aguanomwan33520 sounds like a bad display cable or a bad connection on the displays circuit board. There is really not much that you can request other than trying to replace the display cable or even the display. not sure why Lenovo does not offer repair under warranty since the date of manufacture should be early 2023. Anyhow, use this Lenovo Legion Pro 7 Hardware Maintenance Manual to work on your Lenovo and check the display eDP cable
Punteggio 1
Aggiungi la tua risposta
Aguanomwan Israel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 24
Tutti i Tempi: 652
