Salta al contenuto principale
Il Pixel di terza generazione rilasciato da Google nell'ottobre 2018.
How to clean charging
There is dirt in the shipment and I cannot install it USB How can the problem be solved?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If there is dirt stuck in a usb port, what I have personally found to work is to get a toothpick (preferably plastic) or similar (Something that is sturdy enough and won't break apart or leave more fluff inside) and carefully scoop it out.
I usually use a disposable plastic toothpick/floss and stick the toothpick end in to pull dirt out.
For safety, make sure it is not powered at all. If it is a device like a phone, then power it off just in case. And if the port has any visible pins, be extra careful not to damage them.
I am keeping my answer non-device-specific as it should work for any type of USB port and device. (I know original question is about a pixel phone and I have done this solution many times with my phones that have USB C ports to remove dirt, paper etc.)
Punteggio 0
Aggiungi la tua risposta
ahmed ali sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 32
Tutti i Tempi: 276
