Salta al contenuto principale
Un portatile compatto e leggero con schermo da 14 pollici prodotto da Acer.
My camera is not working
my laptop camera is not working but in device manager it shows cameras in devices and the driver is Acer FHD user Facing but when I open the camera app it says no camera are attached
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Well I will suggest you to do: go into Settings > Bluetooth & Devices > Cameras > Under Connected Cameras, click on your Camera > Click Enable.
Punteggio 0
Restrat laptop and check privcay setting to ensure cam access is enabled.
verify that the camera is enabled and functioning in different apps.
Check bios settings and physical connections
Perform a system scan with sfc /scannow if needed.
Punteggio 0
Aggiungi la tua risposta
SAMAD JUTT sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 15
Tutti i Tempi: 360
