Salta al contenuto principale
L'iPhone SE di terza generazione è stato annunciato l'8 marzo durante l'evento Apple Peek Performance. È dotato di chip A15 e di un display LCD da 4,7 pollici, simile al suo predecessore, l'iPhone SE 2020.
Replaced screen but not working
Old screen now not working either
All connectors look fine
Please help
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
So after doing some googling it was as simple as doing a reset, it has now sprung into life.
Punteggio 1
1 Commento:
Awesome, Justin; glad to hear it was something simple.
da
Risposta più utile
Hi Justin,
You've got an iPhone with a screen made with older LCD technology, which means it has a backlight. It would be worth your time to check to see if the backlight has failed. Take a flashlight and hold it up against the screen and see if you can make out an image. If so, you may have blown a backlight fuse on the motherboard, which would be a tricky repair for us home DIY-ers. That sort of thing usually happens when the screen is connected or disconnected while the battery is plugged in; it rarely is a problem when the battery is disconnected before working on the screen.
Check that out and let us know what you find.
Does the phone appear to be alive in other respects? Does it make any sounds or vibrations when turned on or connected to a charger? Is there a response when plugged into a computer; does the computer recognize that it's there?
Punteggio 2
1 Commento:
Thanks for your help, but all it needed was a reset.
da
Aggiungi la tua risposta
Justin Short sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 13
Tutti i Tempi: 445
