Salta al contenuto principale
Repair guides and support for a wide range of kitchenware.
How can I replace the spinner on my nutriBullet
Repair my nutribullet
Questa è una buona domanda?
Punteggio 0
1 Commento:
you want an answer after providing no information about the product?
da
Aggiungi un commento
1 Risposta
@stevelovely not sure what you are referring to as "the spinner". First you need to identify the NutriBullet since there are a few different models for this. Next check the guides for anything like this Nutribullet Rx #NB-301 Drive Socket Replacement ******Essentially they are all build the same way. Some steps maybe slightly different. That just means you will have to be a bit inquisitive and keep digging for the right way for whatever model yours is.
If you are stuck at any time you can always post some images of the where you are stick situation. That way we can see what you see and hopefully assist you further. Aggiungere immagini ad una domanda
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Magic Bullet NutriBullet Drive Socket
Guida
Difficoltà:
Facile
20 - 40 minutes
Punteggio 0
Aggiungi la tua risposta
Steve Lovely sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 80
