Salta al contenuto principale
Nutribullet Rx #NB-301 Drive Socket Replacement
Cosa ti serve
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: passo 1, immagine 1 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: passo 1, immagine 2 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: passo 1, immagine 3 di 3
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 2, immagine 1 di 2 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 2, immagine 2 di 2
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 3, immagine 1 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 3, immagine 2 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 3, immagine 3 di 3
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 4, immagine 1 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 4, immagine 2 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 4, immagine 3 di 3
    • Remove the drive socket from the motor.
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 5, immagine 1 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 5, immagine 2 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 5, immagine 3 di 3
    • Remove all dust and residue from the area before you replace your new drive socket.
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 6, immagine 1 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 6, immagine 2 di 3 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 6, immagine 3 di 3
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 7, immagine 1 di 2 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 7, immagine 2 di 2
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
Conclusione
Martin G
Membro da: 03/05/24
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 34
