Salta al contenuto principale
Alternativa ai Joy-Con con licenza ufficiale per Nintendo Switch. Rilasciato a settembre 2019, identificabile dai numeri di modello NSW-182 e NSW-182U.
Left stick not taking up inputs
So for some reason whenever I hold up with the left stick on my split pad pro, it just stops taking the input for a split second repeatedly. So for a few moments I can have the input be fine, but then it just stops for a split second. Does anyone know why this happens and how I can fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
This sounds like the same kind of issue you would see with joystick drift. Please see my answer below for that repair.
Drift is a common problem with all joysticks. The best way to solve that problem with with a joystick replacement. The Hori Split Pro appears to be compatible with Xbox joystick replacements like can be found anywhere you search for "xbox joystick replacement". For example: https://a.co/d/5AmYLY1
The existing joystick would need to be removed/unsoldered and replaced with a new joystick. This is a common repair for any controller with a joystick. Search YouTube for thousands of videos on how to do it.
Punteggio 0
Aggiungi la tua risposta
CJ BlueThunder sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 8
Tutti i Tempi: 301
