That's frustrating! If your washer is only using hot water even when you select cold, there are a few possible causes:
1. Faulty temperature selector switch: The switch that controls the water temperature might be stuck or broken.
2. Faulty thermostat: The thermostat that regulates water temperature might be malfunctioning.
3. Faulty water inlet valve: The valve that controls water flow might be clogged or stuck, preventing cold water from entering.
4. Incorrect installation: The washer might have been installed incorrectly, causing the water connections to be reversed.
5. Scale buildup: Mineral deposits might have accumulated in the water inlet valves or pipes, blocking cold water flow.
To troubleshoot, you can try:
1. Checking the temperature selector switch for any signs of damage or wear.
2. Ensuring the water inlet hoses are securely connected and not reversed.
3. Checking the washer's manual for any specific instructions on temperature settings.
4. Running a cleaning cycle or cleaning the washer's interior to remove any scale buildup.
If none of these steps resolve the issue, it's likely a more serious problem that requires professional assistance from an appliance repair technician.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
Hi @firuzvento
What is the model number of the washer?
da jayeff
Kenmore Washer 110.28102310
da Firuz Vento
