Salta al contenuto principale
Il netbook Samsung NP-NC10-KA02US è stato rilasciato il 15 novembre 2008. Questo computer è dotato di tecnologia di retroilluminazione LED, nonché di connettività Wi-Fi e Bluetooth.
Operating system not found
For some days my laptop shows operating system not found I don't know why I searched on YouTube to fix that i even open my bios setup but i doesn't help and then after some time bios setup also not showing on screen i also replace the CMOs battery but it still not showing Could u plsss tell me what should I do...
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hey there, I'm wondering if your hard drive might have gone out. Is the drive appearing in your BIOS' boot order?
da Condividi
Aggiungi un commento
1 Risposta
OP not found is a hard drive issue. However, BIOS not showing might indicate a BIOS issue.
When you turn on a computer, the CPU reads a small piece of code in the BIOS chip. That tells it how to access the hard drive and read the MBR or GPT sectors.
From that info, it can find and load the OS.
Normally, a missing OS would be a HDD fault. Either corruption or a total failure.
Start by trying to do repair install of Windows. Look up how to do that.
if that doesn't work, remove the HDD and connected it to another computer using an external HDD enclosure.
If you can read it, remove all your data - if you do not have a recent backup.
Then reformat the drive and reinstall Windows.
You will have to reinstall all the programs you use also.
Then copy your data back.
Punteggio 0
Aggiungi la tua risposta
Dhruwansh dave sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 268
