Salta al contenuto principale
L'ammiraglia top di gamma Apple per il 2022. Rilasciato il 16 settembre, l'iPhone 14 Pro Max vanta un display OLED ProMotion da 6,7", il nuovo chip Bionic A16, un sistema a tripla fotocamera posteriore e connettività 5G. Successore dell'iPhone 13 Pro Max.
Are copper wires required for button function?
The flex cable (connecting the power button with the volume up and down buttons) that is also connected to the wireless charging coil has been severed. Upon attempted replacement of said flex cable, I discovered that the existing severed flex cable is connected to small copper wires attached to the wireless charging coil. If I sever those wires and just replace the flex cable, will the buttons be operational? Note: I can do without wireless charging as long as I can still charge the phone via the charging port.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
For the circuit to work the connection is required. If you are asking about the wireless charging coil it won’t work if severed.
Punteggio 0
1 Commento:
I just need to know if the buttons will work again. Not concerned about the wireless charging.
da
Aggiungi la tua risposta
Dawn sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 21
Tutti i Tempi: 341
