Salta al contenuto principale
How to replace the screen its brokin
How to change brokin screen
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@ahmedhaldo22325 that is a big challenge. I would suggest you check videos like this to remove your LCD. If you need to find a screen, that is even trickier because of the size. You do want to remove the back cover and then check the label on the back of the screen. Then use that number to try and locate a replacement. Most commonly replacement screens are more expensive as a new TV.
Punteggio 0
Aggiungi la tua risposta
ahmedh_aldossari@hotmail.com sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 17
Tutti i Tempi: 284
