Salta al contenuto principale
The Canon EOS Rebel T7, also known as the EOS 2000D, is an 24,1MP DSLR camera released in 2015.
9 Domande Visualizza tutte
50-80 drop of water by accidentally on my camera
My 200D mark ii camera, I have drop 50-80 drop of water by accidentally on my camera and after this incident it's not working at all not opening, display doesn't showing anything, totally shutdown....I have checked full battery battery is totally ok, I checked the repair centre and they are saying it's a huge problem...I have to paid them ₹10000 rupees, so I have no other option, can your website help me to solve this ?🙏
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @smilebudysid
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Remove the battery from the camera and do not try to turn on your camera again until it has been properly cleaned, internally.
You need to dis-assemble the camera and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a teardown video that may help.
If this process seems too daunting, take your camera to a reputable, professional camera repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Punteggio 2
Aggiungi la tua risposta
Smile Budy SiD sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 132
Ultimi 30 Giorni: 250
Tutti i Tempi: 563
