Salta al contenuto principale
Lo Xiaomi Redmi 9A è uno smartphone economico prodotto da Xiaomi e rilasciato nel giugno 2020. Dispone di un display LCD IPS da 6,53", una fotocamera principale da 13 MP, una batteria da 5000 mAh e monta un processore Helio G25.
My phone internet doesn't working
When I started internet it doesn't work .
Questa è una buona domanda?
Punteggio 1
1 Commento:
no internet connection to my redmi 9A phone
da
Aggiungi un commento
2 Risposte
Hi @rohitsaini
Check the data saver setting in the phone is not set to prevent data access.
Go to Settings → Sim cards and mobile networks → Set data plan → Enable Data usage → Data plan.
Punteggio 0
Restart Your Phone: Sometimes a simple restart can fix connectivity issues.
Check Wi-Fi Settings: Ensure your Wi-Fi is turned on and you’re connected to the correct network. If you are, try forgetting the network and reconnecting1.
Check Mobile Data: If you’re using mobile data, ensure it’s turned on and you have a good signal.
Reset Network Settings: Go to Settings > System > Reset Options > Reset Wi-Fi, mobile & Bluetooth. Remember, this will erase all network settings, including saved Wi-Fi networks and Bluetooth connections.
Update Your Phone: Make sure your phone’s software is up to date, as updates can resolve many issues2.
Restart Your Router: If you’re on Wi-Fi, try restarting your router.
Punteggio 0
Aggiungi la tua risposta
Rohit Saini sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 42
Tutti i Tempi: 731
