Salta al contenuto principale
Il Google Pixel 7a è la variante economica della serie Pixel 7. Rilasciato nel maggio 2023, il Pixel 7a migliora rispetto al Pixel 6a grazie al riconoscimento facciale, 8 GB di RAM, fotocamere notevolmente aggiornate e ricarica wireless.
Screen adhesive re-use
Just completed a glass/screen repair on a Pixel 7a, but got a smudge on the front camera lens during the process. Sadly, didn't notice until after reassembly was complete. Can I re-open the front, clean the lens, and re-close without replacing the perimeter adhesive, or do I need to clean up and use new glue?
Questa è una buona domanda?
Punteggio 1
1 Commento
Thanks folks, for the minimal cost of new screen adhesive, it's worth the reassurance that it'll be properly sealed.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
I'd say it depends on how well the glass comes off. I had an iPhone X that I had just finished working on but banged my head on the table when I realized I'd forgotten to reprogram the True Tone data. So I opened it back up and found that the precut adhesive had stuck on the phone so it was still completely intact and undamaged. That being the case, I decided to reuse it and haven't seen any problem as a result.
So my take on this as it applies to you is, if the display comes off cleanly and doesn't tear or stretch the precut adhesive, you can probably get away with reusing it. If it sticks partly to the screen or tears / stretches when you get the screen off, then it's time to replace it.
One thing you might do when you put the phone back together is to reheat the adhesive once the screen is on, then place it face down with some weight on it. That'll soften the adhesive and the weight will help seal it. Hopefully that'll help compensate for not using a new sheet of adhesive. I usually go over the phone for about 3 minutes with a hair dryer, then I have a motorcycle battery I set on it for a half hour or so.
Punteggio 2
You could, But I would highly recommend not to
Punteggio 0
2 Commenti:
Not nay-saying your answer, I'm genuinely curious: voice of experience, or theoretical problem potential?
da
There’s a potential problem
da
Aggiungi la tua risposta
Frudougy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 54
Tutti i Tempi: 1,241
