Salta al contenuto principale
Il notebook MSI GL65 9SD è un computer portatile da gaming di fascia economica prodotto da MSI e rilasciato nel 2019. Qui puoi trovare guide di riparazione e ulteriori informazioni.
Why is my screen off
Please a metal screw fell inside the laptop, stacked between the metal that covers the cpu and the motherboard. I didn’t know so I connected my laptop charger to the laptop and the charger light went off. I tried this several times until I opened the laptop and removed the screw. Now the laptop turns on but the screen is off. When I connect to a monitor, it doesn’t show too. Please what could be the fault
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You seem to have loosened the heat sink (that metal part) if the screw got trapped onto the motherboard than it is possible that you damaged the motherboard (really bad). You could also try to check the connection to the GPU and the actual card itself for damage and the fragile ribbon cables around it
Punteggio 0
Aggiungi la tua risposta
Michael Ashorm sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 227
