Salta al contenuto principale
Lo Xiaomi Poco X3 Pro è uno smartphone di base di Xiaomi uscito a marzo 2021. È dotato di uno schermo LCD IPS da 6,67", una fotocamera principale da 48 MP e funziona con Qualcomm Snapdragon 860.
Why does WiFi not work?
My phone is Poco X3 basic version
A year ago my WiFi stopped working
Only my House's WiFi would work and no else WiFi I then started to use Mobile data
Even the hotspot won't work and after sometime the Bluetooth stopped working too
The phone didn't had any changes and it's performance was great
I asked a guy he said that there is a software issue but he couldn't solve it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @mrreaper13236
Try using the phone's WiFi (or BT) as close as possible to your home network router (or BT device) i.e. <10cm and check if you get a stable connection.
If you do it may be an antenna problem in the phone. Loose connection perhaps.
Here's an image taken from the ifixit Sostituzione Schermo Poco X3 Pro guide] showing the location of one end of the antenna. The other end is under the module.
(click on image)
Punteggio 1
Aggiungi la tua risposta
MR REAPER sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 201
