Salta al contenuto principale
Informazioni e guide di riparazione per la quinta generazione di iPhone. Modello: A1387
iPhone 4S No Backlight Issue
I have an old iPhone 4s that has no backlight, but if I hold it in light I can see the LCD working. I have tried restoring in iTunes and replacing the screen. There is gunk on the capacitors near the display cable so could that be it? If so, how can I remove it without knocking the components off the board? The previous owner had it sitting in a closet for years, so dust and gunk could have accumulated then.
EDIT: I don’t know what I did, but now the backlight turns on for a second showing the Apple logo, but then turns off again and won’t illuminate
Immagine
Immagine
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
could be a bad backlight filter
Update (04/20/24)
check that filter for continuity
Immagine
Punteggio 2
4 Commenti:
How could I fix that?
da
@braydendcooper it requires microsoldering equipment its not an easy repair for just anyone. have you got a multimeter
da
Yes, I do have one
da
@tech_ni the filter has no continuity.
da
Aggiungi la tua risposta
Brayden Cooper sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 22
Tutti i Tempi: 469
