Salta al contenuto principale
Steering and electric problems
The steering is so heavy and the camera is not working what cause this problem car tucson 2013 limited edition
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Greetings Otaku,
Have you checked the fluid level for the power steering fluid? Is the belt slipping or missing from the power steering pump? In addition to this a sudden heavy steering issue is a symptom of a failing or failed lower ball joint.
The camera I would start by checking fuses, wire harness specifically where the camera goes into the back trunk and connections.
Cheers!
Monte
Punteggio 0
Aggiungi la tua risposta
Otaku Gamesッ sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 424
