Salta al contenuto principale
Guide di riparazione e supporto per i tablet Lenovo ThinkPad, inclusi il ThinkPad Tablet (2011), il ThinkPad Tablet 2 (2012), la serie Helix e il ThinkPad X201 Tablet. Questi modelli utilizzano Android o Windows e coprono le uscite dal 2011 alla metà degli anni 2010.
Won't turn on
I recently got a Lenovo thinkpad tablet 1 from a friend but no matter what charger I try I can't get it to turn on! I am using a 5v 2a charger so I know that's not the problem but no matter what all I can do is hold down the power button for a bit to get it to buzz but that's it. No amount of using the reset button has resulted in anything.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
In some models you can enter the recovery mode by holding the volume up button and the power button, and once the Lenovo logo appears let go of the power button but keep holding the volume button until it enters the recovery mode. Then you can navigate with the volume buttons and select with the power button.
da
@honakrisi now it buzzes twice but still nothing in screen
da
doesn't sound too good... Has it ever suffered water damage?
da
Aggiungi un commento
1 Risposta
@david227156 try something like this
Power system checkout
To verify a symptom, do the following:
  • 1. Turn off the tablet.
  • 2. Remove the internal battery
  • 3. Attach the tablet to a ThinkPad Tablet Dock (hereafter referred to as the dock) and then connect the dock to an electrical outlet using the 65 W ac power adapter shipped with the dock.
  • 4. Check whether power is supplied when you turn on the tablet.
  • 5. Turn off the tablet.
  • 6. Disconnect the ac power adapter and detach the dock. Then install the internal battery.
  • 7. Check whether the internal battery supplies power when you turn on the tablet.
Use the ThinkPad Tablet Hardware Maintenance Manual to work on it. Open it up and let's see what you got going on there. Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
david 2 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 396
