Salta al contenuto principale
Il OnePlus Nord N100 è stato rilasciato il 15 gennaio 2021.
How to clean the back camera
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
I don't know why you really need to, but use isopropyl alcohol
Punteggio 0
1 Commento:
If I may, I'd like to add to this in that you should stick with rubbing alcohol that is a 90% or higher concentration of isopropyl alcohol. The 70% stuff we all have lying around the house has water and other additives in it that you don't want getting into your phone.
Of course, this all hinges on us thinking you want to clean the outside glass lens on the rear of the phone; if it's something else you have in mind such as some sort of obstruction inside the case that's interfering with the rear camera, then that's a whole different issue and you'll need to tell us if that's the case.
da
Back cemra change
Punteggio 0
1 Commento:
Cemra change
da
Aggiungi la tua risposta
Rami sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 13
Tutti i Tempi: 282
