Salta al contenuto principale
Informazioni per la riparazione e la soluzione problemi del Lenovo IdeaPad 5 15IIL05. Il portatile Lenovo IdeaPad 5 basato su Intel è stato rilasciato nel 2020. Include dettagli per l'identificazione del dispositivo, specifiche tecniche e problemi comuni come guasti alle cerniere e al pulsante di accensione.
Hinge Broke LCD Display
My laptop is about 3 or so years old and has been dropped a few times, however it wasn't until recently that the back right hinge broke off from the LCD Back Cover breaking some of the plastic off with it. I am trying to figure out what I am needing to buy in order to repair it. Any idea what I am needing?
Immagine
Immagine
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
2 Risposte
@andrewboot16282 most likely the ninges since they got stuck, unless you get them to move smoothly again. Soak those in some WD 40 and continue to work them until they are no longer sticking. Lubricate them after they are clean and dry with some 3-in-1 oil and work it into the hinges by opening and closing those a couple of times. If the hinges are bend or otherwise damaged, you will have to replace those.
Next parts to replace would be the middle frame where the hinges screw into and the LCD cover. Now, we do not know the condition of the top case, that is the part where the keyboard sites in etc. That you will have to evaluate as you open your computer.
To work on your Lenovo use the Lenovo IdeaPad 5 15IIL05 Hardware Maintenance Manual
Punteggio 0
My laptop hinge broke twice and this is the third time. The screen was not damaged. Can this be fixed?
Punteggio 0
1 Commento:
@marialopez49572 possibly but we need to know more about it. Make and model is a good start. How did you fix it the first two times?
da
Aggiungi la tua risposta
Andrew Booth sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 51
Tutti i Tempi: 1,707
