Salta al contenuto principale
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
2012 Door window dont work
2012 ford expedition door window repair
Update (03/17/24)
2012 ford expeditiondoor window its stuock
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
5 Risposte
Risposta più utile
Have you checked the fusebox for broken fuses or breaks in cables related to the window? Anything blocking it from moving? A broken hoist mechanism for the window inside the door can also give these problems.
Punteggio 1
Most likely a broke window regulator motor those go bad causing the window to be stuck
Punteggio 1
Problems with the automatic transmission
Update (09/13/24)
when it is hot it disconnects and does not work properly
Punteggio 0
When it is hot it disconnects and does not work properly
Punteggio 0
Punteggio 0
Aggiungi la tua risposta
Ama sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 19
Tutti i Tempi: 296
