Salta al contenuto principale
Le trivellatrici Ground Hog (modello HD99-H) sono trivellatrici idrauliche trainabili con velocità di avanzamento variabile e rotazione inversa della punta. Il modello HD99-H può scavare buchi con qualsiasi punta fino a un diametro di 45,7 cm.
Where can I find the proper bit
We have the HD-99 not the HD-99H and when we order the bits from Ground Hog they send us a bit that is too shallow and will not fit. The current bit is a SB-25 with the number 1986 stamped above. The Drill itself has 12-C5 stamped on the bottom of the drill. There is a decal that has DC-DARA on the shaft of the drill. Can anyone help me with getting this bit as we have none of the bits working that came with the unit. Thank you
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @jobewood
Can't find the bits as per the info you posted but if you don't get a better answer perhaps try using a suitably sized hub adapter to get the bits you already have working.
If there is a suitable size adapter listed for the auger and the bits sizes, search online for Pengo (insert part number (pn) of adapter) to find suppliers that suit you best.
Punteggio 1
Aggiungi la tua risposta
Jobe Wood sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 22
Tutti i Tempi: 547
