Salta al contenuto principale
speaker not working properly?
Low and muffled sound coming from the speaker
Questa è una buona domanda?
Punteggio 2
1 Commento:
Speaker not working
A33 samsung
da
Aggiungi un commento
2 Risposte
Hi Mehmet,
If you look at the bottom of your phone, you should see a speaker grill.
Is it clogged? if there is dust or other debris blocking the grill it will lower your speaker's performance.
Let me know what you see, and we can take it from there :)
Punteggio 0
Dust is there
Punteggio 0
1 Commento:
Use something like a pair of small tweezers or a needle to gently clean out the charging port. Please be careful of the metal contacts on either side of the plastic piece in the middle of the port. Scratching or otherwise damaging these could result in a loss of charging functionality
da
Aggiungi la tua risposta
Mehmet Buğra Avcı sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 29
Tutti i Tempi: 490
