Salta al contenuto principale
Informazioni su riparazione e smontaggio delle cuffie over-ear wireless a cancellazione del rumore Sony WH-1000XM3.
Right speaker Isnt working.
The right ear cup isnt producing any audio. The swipe functions on it still work when switching songs and pause and unpausing. Also the left ear cup does produce audio. The headphones can charge and the noise cancellation features also still work.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
I assume you are speaking of wireless operation. Is it the same with cable? If yes, then It must be speaker problem.
If the rt works with cable, then it is a problem with the internal PCB.
Punteggio 1
3 Commenti:
yes this happens both using a cable and with bluetooth. If its a speaker issue how do i fix it or is it worth buying a new pair?
da
the problems with fixing them is;
1. finding the right part
2. opening up the earphone without breaking something
3. removing/replacing the speaker
4. reassembling
Of course, you probably want to open first to berify the speaker is bad.
If you get a none exact replacement, do you have a critical ear such that you will hear the diff?
da
I appreciate the help, I'm probably going to go to a place and get it fixed there. I've had these since 2019 and I don't want to risk breaking them more. I do really appreciate your help though.
da
Aggiungi la tua risposta
Abel Mekonen sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 29
Tutti i Tempi: 527
