Salta al contenuto principale
Cuffie stereo della serie ZX MDR-ZX100 prodotte da Sony.
Which cable is which?
Green with what? Red with what? What are the other cables near the green and red ones? Ground???
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
@silviurec you should have two set of wires. One set Red/Copper and the other set Green/Copper. Red wire is Right Speaker + and Coper is Right Speaker Gnd. Green wire is Left speaker + and copper is Left speaker ground.This is where you need to connect the wires to:
Left = Tip
Right = Ring
Ground = Sleeve Both of the Copper wires get soldered on that pin
Something that looks like this will work for your headphones.
Immagine
img from here
Punteggio 1
Aggiungi la tua risposta
Silviu Rec sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 211
