Salta al contenuto principale
Informazioni per la riparazione della stampante fotografica a getto d'inchiostro all-in-one Canon PIXMA MG6660.
Where is the WPS button
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
@ericliddell should be in your settings menu. It does not look like your printer has a physical button. Let's assume you are trying to setup a wireless connection. use the instructions from here You can also download the MG6600 series Manual from here It will help you with your setup.
Punteggio 1
1 Commento:
Every printer I've had doesn't use a button, it's always in the network setting. Don't have a demo Canon, but I do it on the HPs from Network>Wireless setup wizard for the screen versions or WPS on some old 2-liner models. My gently used (with a bad imaging drum) monochrome laser uses the app under Network unless you enter it manually or use WPS.
I suspect Canon is similar.
da
Aggiungi la tua risposta
Eric Liddell sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 12
Tutti i Tempi: 335
