Salta al contenuto principale
Rilasciata il 3 Dicembre 1994 in Giappone e il 9 Settembre in Nord America. Modelli SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x e SCPH-900x.
Open button stuck even after cleaning
So for some reason one of the Ps1s that I have has a stuck open button. I took it apart, cleaned the button and socket, put it back together and the button still gets stuck. Maybe the spring is bad?
Questa è una buona domanda?
Punteggio 0
1 Commento:
or button too loose, as in diameter not quite large enough.. happened to me
da
Aggiungi un commento
1 Risposta
My solution to this problem was using a little bit of dry lube to let the assembly slip better. Another fix was sanding down the insert part where it makes the \___ shape at the end down to better work with the spring.
Punteggio 0
Aggiungi la tua risposta
ryansrepairshop sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 29
Tutti i Tempi: 345
