Salta al contenuto principale
La Ninja Coffee Bar CF086 è una macchina per il caffè dotata di caraffa termica da 43 once (1,27 litri) e tecnologia Auto-iQ One Touch Intelligence.
Digital display not working
My digital display has stopped functioning and you can’t see the numbers anymore for setting the brewing time in morning. Any idea if parts can be ordered to replace the LED display on it instead of replacing the whole thing.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
The part you're looking for is probably the display unit, and I found a potential match here: SunnyLED Display. However, sourcing this part domestically poses a challenge. While it's available for direct purchase overseas, the long shipping duration could be a major inconvenience. If you're reliant on your coffee maker daily, this might not be the best route.
A creative workaround could be scouting for a non-functional coffee maker on platforms like eBay, OfferUp, or Facebook Marketplace. This way, you can harvest the display part. It's a more sustainable approach and might even save you some money!
Another idea would be to disassemble the coffee maker to gain access to the part itself and verify the part number matches the one I linked above. If it does, take it to a local repair shop that is skilled in microsoldering. They may have the right equipment to repair it for you. If it doesn't match what I linked, do a Google (or preferred search engine) search for the part number and see if any local sources come up. You can also try searching on eBay for that part number just in case.
Punteggio 2
Aggiungi la tua risposta
Coffeemomma sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 46
Tutti i Tempi: 2,468
